krash wrote:Well, you have 460lb-ft/455hp moving a 3,300lb car vs 175lb-ft/170hp moving a 3,500lb car.
And heres the thing, CVTs are actually not BAD. Theoretically they're awesome. It keeps the motor at its optimal RPM for power and infinitely adjusts gears for that. We use one on our Baja car, its a good application. However, Nissan is not building that CVT for awesome, and CVTs are just not fun to drive at all lol.
Thanks krash, I understand that CVT's are not bad per se, but they do have their issues and as you said not fun to drive. Nissan CVT's have to use only Nissan NS-2/3 fluid and needs to be filled perfectly otherwise fail safe can happen. It needs to be at a specific temperature or else fail safe happens.
I just cannot wrap my head around how a car with SO much HP can get almost as good if not better mpg with a regular transmission than one with a CVT, which as you said can operate at infinite gear ratios? Doesn't a V8 use more gas than a V4?
I remember growing up and people saying if they could design a transmission that had a lot more gears, or ratio's, cars would get much better mpg and save a lot of fuel.
I assume I am missing something about Torque since you mentioned it...
Reading it on Wikipedia it explains a transmission as:
Most modern gearboxes are used to increase torque while reducing the speed of a prime mover output shaft (e.g. a motor crankshaft). This means that the output shaft of a gearbox rotates at a slower rate than the input shaft, and this reduction in speed produces a mechanical advantage, increasing torque. A gearbox can be set up to do the opposite and provide an increase in shaft speed with a reduction of torque. Some of the simplest gearboxes merely change the physical direction of power transmission.
Many typical automobile transmissions include the ability to select one of several different gear ratios. In this case, most of the gear ratios (often simply called "gears") are used to slow down the output speed of the engine and increase torque. However, the highest gears may be "overdrive" types that increase the output speed.
Torque:
Torque is part of the basic specification of an engine: the power output of an engine is expressed as its torque multiplied by its rotational speed of the axis. Internal-combustion engines produce useful torque only over a limited range of rotational speeds (typically from around 1,000–6,000 rpm for a small car). The varying torque output over that range can be measured with a dynamometer, and shown as a torque curve.
I can read those definitions but still don't grasp it for some reason.
