Someone answer this question for me.
Brent.S14
Car: 1995 Nissan 240sx Coupe-Totaled 1991 Nissan 240sx Hatch-Recent
I currently purchased a ka24de engine from my friend (Who drives an s14, and I drive an s13) that came out of his car. I had planned on putting this in my car, I have everything ready to go, motor is fully rebuilt now, and I have the ECU and wiring harness, now here come's the "He's an idiot" question. Can I use my s13 transmission for this motor or am I going to have to get an s14 one? :/
drewce
You can use your s13 ka24de transmission.
Brent.S14
Okay, now I wish I would have edited the first post. I currently have a single slammer in my car (Came with the hatch when I traded my totaled s14, I raised a lot of question because it isn't suppose to be in the car because it's a 91) Will the transmission still work? Sorry for such a noob question, I just need to know, lol.
Dazzla
Yeah its the same stuff. Only downside is the transmission is old as hell.
AAV240sx
Car: '89 240sx ka24e-t
E39 M5
If I remember correctly, newer obd2 ka24de trans have a hole for the crank angle sensor, which a ka24e transmission won't have. You'll probably have to drill a hole for the sensor or swap the bell housing.
rocksteady_racer
Car: 90 240sx Hatchback (Manual - boosted soon KA24e)
Second swap bell housing. The DOHC trans bellhousing won't bolt up to the SOHC engine or vice versa that is why I bought a diff trans for my dohc lol.
rocksteady_racer
And trying to find a bell housing anywhere is like trying to the find the holy grail
Brent.S14
Thank you everyone for the answers. I do believe I still have an extra DOHC bell housing so I'm good. :D
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
the dohc transmission from a s14 bolted right up to my s13 sohc. i don't no what you guys are talking about. I just didn't plug in most of the sensors. actually the only wires i got plugged in is for the speed sensor. and my cruise works and everything. I guess that's something that most people have trouble with?
Taylor008
Car: 240sx Coupe
Agree with rsagen. I'm using a SOHC transmission with a my DOHC S14 motor in my S13. Bolts up fine.
OP, you will also need a s13 dohc distributor. Just so you know. UNLESS you are rewiring the S14 interior plug to fit your S13 one.
Brent.S14
I do believe I have a distributor, if not then I guess I can get ahold of one cheap from one of the guys around here.
E7-S14
Car: ess 14 foo!
rocksteady_racer wrote:Second swap bell housing. The DOHC trans bellhousing won't bolt up to the SOHC engine or vice versa that is why I bought a diff trans for my dohc lol.
Send your BS WRONG info elsewhere.
1sikS13
Car: 1992 S13 240sx
you beat me to it
Brent.S14
Lol! Thanks guys for the bellhousing info. I still have a DOHC one so even if they weren't able to bolt up (Which I questioned anyway...) I still had an extra haha.
rocksteady_racer
Bah nm - I was misinformed... but at least I have a sweet rebuilt trans lol, Anyway so that answered your question - now if you use a clutch from a dohc on your sohc all you need is a new pilot bearing ;).
