Here's my dillema though.
The P.O. had the engine partly broken down for lifter replacement before saying screw it and thus far I'm pretty sure I've gone around and fixed most of the things left in his wake. Since the timing cover/timing belt and cam gear were off I figured it would be a perfect time to replace the water pump, timing belt, idler and tensioner with brand new OEM parts. I did as the FSM says and lined the timing marks on the cam gears and crank gear to their reference marks and installed the belt (facing the right way) with all the factory marks on their respective gear tooth and tensioned it. Turned the engine 720 degrees clockwise, didn't hear anything interfere, the cam gears went back to their respective alignment marks and all seems gravy. FINALLY THE QUESTION: Shouldn't the motor now be at piston #1 TDC with the cam marks lined up on their marks? Because my tick marks on the harmonic balancer are closer to the left edge of the lower timing cover than the reference bump you're supposed to be able to use to time the engine... Is it possible the timing is off even though all of the marks on the sprockets and belt lined up when installed? Or is this timing belt installation position not TDC position on the motor?
Everything seems fine with the timing components I installed and it all seems to turn fine without any interference in the engine, I just can't get why the harmonic balancer marks would be so far off...
Thanks in advance to anyone who can shed some light on this! Just want to make sure everything is how it's supposed to be before I turn the key
