highintheskyy »
https://forums.nicoclub.com/highintheskyy-u45323.html
Fri Oct 06, 2006 10:53 am
i have a 1995 nissan 240sx if 86,000 miles. It ran perfectly up until about 2 weeks ago. The cars rpms would drop quickly which would make the car shake. This happens mainly in low gears and sitting in idle and it hardly happens when the cars in park. the engine just shakes as the rpms go up and down, and ill give it gas and will will do the same shaking until i give it alote of gas and pick up speed and it goes away. When i hit high speeds or even anything above 40 mph it kinda goes away.
When i first noticed this i changed my oil, filter, and spark plugs. My friend recommended i change my O2 sensor. But the problem persisted. So i read about the ecu and how to read the codes form the articles on this page, and it read out the number 34, which is a knock sensor, so i wasted no time, i bought the knock sensor and had it proffessionally put in......still mycar shakes violently at idle and low speeds. I checked my transmission fluid, oil, i even tried a new plug in each cyclinder. I dont know what to do.....?!!??!?! I recently checked my ecu again and it read out a 33, 34, and 37 in mode II. which means front O2 sensor, knock sensor, and closed loop. (what does closed loop mean? i changed the other 2 already.) then in mode I im getting a solid red light when i turn the car on, which the article on this site says if i get a solid read light that either my crank angle sensor or ECU is bad. I dont know what to do..if anyone can make any sense of my situation, please help me...any advice will be well taken and attempted.
