RAP »
https://forums.nicoclub.com/rap-u76868.html
Fri Jan 18, 2008 4:24 am
At this point Im guessing it was the mix door that blocked the heat from coming through. I still have no idea why the car over heated, where the white grease came from and if the car is salvagable at all.
If the car has the viscous cooling fan clutch the "white grease" would probably be coming from there. That clutch is the type with an aluminum hub with fins, at the center of the fan. That hub is filled with a "grease" which expands when hot thus dragging the fan into play. I think that they can become defective and sling out the "viscous" substance although I've not seen one do this. At least they are for sale at the parts houses so...
The engine cooling fan was probably not turning if that was the case. That would cause your overheating, possibly. Maybe the damage is not as bad as you think depending how long you ran the car "hot". I would try and find a junkyard replacement, complete fan with clutch, since an "OEM" will set you back a bundle. Or, better yet, borrow one from a friend if available. Just ensure that the replacement does not have any signs of grease around it. Make sure that the cooling system/rad is full and crank 'er up. If you did any damage by running the car "hot" it's done, and will soon show it's ugly self.
Disclaimer. Not having been under the hood of your year model Q45 I can't state the above for sure. My 2000 Q45 does have the viscous fan clutch. My '91 GMC P/U is also equipped with same.
Good luck,
Jack
