Mishka »
https://forums.nicoclub.com/mishka-u16371.html
Wed Feb 22, 2006 3:19 pm
If the ECU doesn't give you any trouble codes for KS, then it is OK. Just make sure that EGR is the only code you are getting.I've heard about resistance check on knock sensor, but i'm not sure how to perform it exactly. Simple visual inspaection will give you clue. If plastic is cracked replace the sensor.From a dealer it's about 150.00,I have bought mine from e-bay for 78.00 shipped.
