Yeah dude, there are a lot of different possibilities. I would get in there and just clean out everything you can. Run some Seafoam, change plugs, clean the TBs, clean out the EGR tubes while you're in there, clean the MAF sensor connections (if you didn't before).coolyun_98 wrote:I share ur frustration!
There are most likely MORE than 1 problem with ur J.
Stall + hesitation = spark plugs? ignition coil? fuel filter? dirty throttle body?fuel regulator/damper? fuel pump? dirty/failed fuel injector? timing is off? knock sensor bad?
unstable idle = dirty IACV valve? dirty throttle body?
usually these two problems manifest each other.
Start from the simple soluton first! run a can of BG 44K, change spark plugs, change fuel filter.
good luck
Does your air take a long time to heat up?heyhi wrote:My temp gauge hasent worked for a long time what could that be. do u think leaving it not working caused some problems. Im gonna change the thermostat. I already changed the plugs. what else can i check for to fix this. thank you guys
@ 40 and 80 wouldnt you hear it grind????i can get passed 40 and 80 if its over 3800 rpmsEbbtide wrote:Maybe it's the transmission slipping?
Do you have a copy of the FSM? I believe there's a site where the '94, or maybe it's the '95, manual can be downloaded for free.kbflip02 wrote:@ 40 and 80 wouldnt you hear it grind????i can get passed 40 and 80 if its over 3800 rpms
i do have a copy of the FSM...also the website is PHATG20.COM if im not mistaken....and my temp gauge works fine....as far as idle in park-800 idle in drive 700GerryO wrote:
What's the engine idle rpm speed sitting still with the engine fully warmed up, your foot on the brake and the transmission in Drive?
Is the temperature gauge simply not working or could the sender be bad or could the thermostat be stuck OPEN, lengthening the engine warm-up time and possibly not communicating necessary info to the ECM?
I apologize for the confusion, as my reply was directed to heyhi.kbflip02 wrote:
Sounds like it's time for a new MAF.heyhi wrote:I just warmed my car up put it in drive and the rpms dropped from 700 to about 100 and wanted to shut off.usually my idle cold is 700 and when warmed up it jumps to about 1800 down to 700 over n over
I have a service manual on cd rom. I also check my maf sensor and it reads.021v ignition on and .031v car warmed its suppose to be .8 ignition on and between.8 and 1.5 car warm
