some white guy's build thread. (s13 coupe)
some_white_guy
Car: '90 240sx white coupe
well she runs....like s*** lol. i put my foot to the floor and it takes 5 seconds to go from 2 grand to 3grand in 2nd gear but she is home and washed. my dad's tech is gana look at it tomorrow or next week or something the timing is probably not even close.
first bath! finally some results.
took 23 days to get from a torn apart car to driving her home
thomasjamal
Car: 93 coupe
zach-Ka wrote:
some_white_guy wrote:i just got them as clean as i could and sprayed them, its a temporary fix till i buy oem pieces to replace them, the paint is already kind of scuffing off on some places so i dont think its going to stay clean for very long.
So would you say that it's not worth it? Or do you think with more prep it would be fine?
I used the same stuff to paint my brown interior black on my coupe too. I painted everything except the seats: panels, dash, carpet, headliner, everything. It looked really good for at least a year and held up well for about 2 years. After that it started to bubble up and peel off some of the panels. It gets scratches fairly easy too but the nice thing is that it's easy to touch up if you just keep a can of it around.
After 2.5 years or so I finally went and bought a full black interior (except the headliner, it still looks great).
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
Hi :wavey: Some white guy. I am some black guy. :biggrin: naw but seriously i had the same problem your probaly off a tooth on timing.
xiaphin
Car: 10' Genesis Sedan 71' Datsun 510 90' S13 Fastback SR
Painted interior in my S14 couple years back with some vinyl paint using an HVLP spray gun. Prepping does help. According to my paint guy at napa you need to do these things.
1. Wash with soap and water (Dawn works best)
2. Rough up with either white or gray scotch brite... depending upon material type...
2. Wash again
4. Dry with time or air
5. Paint
Will be doing my whole interior in about a week or two... You can follow my build thread in my sig if your interested...
On a side note you can have paint color matched with their spectrograph and get it special mixed for vinyl applications if you have a spray gun. And of course get paint that is specifically for vinyl/interiors. SEM makes good stuff.
some_white_guy
so i pulled the head again today because i thought the head/block might have been warped from the PO i found 3 dirty piston heads and 1 clean which i figure means i have a leak somewhere. machine shop picks up the head tomorrow and i'm thinking about porting the intake and exhaust while its off, do you guys think it will add some power? i dont have any pics but when the head comes back i'll throw some up. what should i do to upgrade the head so i can go boost in the future if i feel the desire (which i'm sure i will).
some_white_guy
car is almost back together, need to put the clutch fan and intake back on and then i'm done
some_white_guy
so bad s*** happend today...
0 oil pressure, there is 0 oil running through my engine, i took the cap off the valve cover and the head was completely clean :facepalm:
i started dropping the oil pan just to see if there are any leaks or if the screen fell off/broke and i'm probably going to need a new pump and sender.
backpedaling sucks balls. hopefully replacing the sender wont be a b**** and luckly the pump is an easy replacement
pjxiong
Car: '89 Nissan 240SX Coupe
wow, white guy from san jose with a white 240 coupe? sounds all too familiar. wait, i bought an '89 white 240 coupe from a white guy from san jose back in august! anyways, hopefully you get your engine taken care of. btw, i wasnt joking, here it is:
some_white_guy
haha nice car, you and me both need front lips
danmansil80
Car: 1989 black hatch s13 ka24de rebuilt forged bottom end.
Dude I couldn't see any of your picks :(
Chaluska
yea, flickr FAIL
Imageshack.us is full of win
240sxcl50
Car: 95 s14
danmansil80 wrote:Dude I couldn't see any of your picks :(
same here bro :confused:
Safo
Car: 1995 240SX SE
Nooo, pics are gone.. :inout:
danmansil80
I used Facebook. Just make sure you are looking at a blown up picture. Right click and select copy image address. Then do the rest on here
