Slappy wrote:
Will you please post pictures and specs on your car?
....and what camera are you using?
Here
http://boostrot.net/gallery/v/....html is a pic with the latest colors. There are a few others in that gallery also.
The car is prepared to SCCA's Improved Touring A class specs, which includes: *interior gutted, six point cage, race seat & six point harness*Ground Control suspension w/Koni sport shocks/struts, ERS springs (450/325), GC front camber plates, poly bushings, solid subframe bushings*Torsen-type LSD with 4.36 gears*engine bored .020 over, balanced/blueprinted/decked, Wolf custom ECU, modified S&S header into custom 3" exhaust*ACT HD clutch w/4-puck disk*many more little things, like stainless braided brake lines, ARP wheel studs, Koyo rad w/Flexalite fan, and so on...
The video was shot with a Sony handicam mounted to an I/O Port camera mount, attached to the cross bar on the main hoop.
