eastcoastchaos »
https://forums.nicoclub.com/eastcoastchaos-u4408.html
Sun Jul 26, 2009 10:04 am
ticking would be from valves with too much clearence which will not cause a loss of compression, if it's even the valves making the tick. do another compression check, then right after the bad cylinder put a little oil down the spark plug hole and check again. If the comp jumps up a lot then your rings are probably bad or installed with the end gaps lined up which is bad. If comp doesn't change much then your down to either valves or head gasket. If your oil looks milky and coffee like it's probably the gasket, if not then look at valves. valves are easy to check and with the right tool you don't have to pull the cams to swap shims because there over bucket shims.
