Some useful Oil Info for the Season
PalmerWMD
Car: 2004 350Z
A good oil article explaining "stuff":http://www.machinerylubricatio...nance
Here is an oil discussion from our NICO Infiniti board(long):http://www.nissaninfiniticlub....37349Some examples how even sludge prone engines can be taken care of:http://www.nissaninfiniticlub....48815
And FINALLY: a list of some of the BEST oils!(for turbos in summertime, you may use thicker versions of these exact same ones):http://www.nissaninfiniticlub....=6610
Fred...
onosqv
Car: '92 240sx Vert
Links need to be updated from http://nic... -> http://forums.nic...
slipnfall
Car: '06 D40
Fred I just wanted to note that I took your advice and have been using Mobile1 0W-40 for the last 3-4 months in my n/a 240sx and love it! You touted it as an all-year-round weight, which is mighty convienient. There are plenty of people who think it's a very wrong weight, but I have noticed a decrease in valve train noise, even in arrid NewMexico heat. It gets moving very quick, which is good for me because sometimes I like to just get in and go!
'slip
Links fixed - Good info, great reading!
McRussellPants
Car: 92 240SX
Amsoil > *
That is all.
Z U L8R
Car: 78' DATSUN 280Z + RB20DET , 71' DATSUN 240Z + RB25DET
Seems like everytime I use synthetic in my sr20det's i blow up my t25's LOL. Time for a bigger turbo anyways :D
artemous
Car: 95 240sx Ka24de. 81 datsun king cab. 9 corvairs
Synthetic oil does tend to lower oil pressure a bit over dino oil (if your running normal temperatures) Maybe your having turbo problems because your running borderline oil pressure problems to begin with. Try a heavier oil.
SpoonZor
Car: 2006 Scion TC
Im About to buy a 240 off a guy and im lining up a SR20 but i have like the one thing i havenet figured out what oil filters do u use for the swap. Do you use like the 200sx sr20 oil filters or what .
artemous
Why do you want to swap. With the same money into upgrading the KA you will produce more HP and much more torque.
As for filters, use a filter from a Sentra SE. They run the 2.0L Use a good oil filter, K&N, Mobil 1, Purolater. Not fram.
