Some useful information regarding valve springs
Ezekial
Car: 2001 Nissan 200SX S15
Found out what the inner valve springs are from
GTiR SR20DET
Identical valve springs as in the VH45DE engine however VH doesnt run inner springs ... so if you use GTiR inner springs it gives a nice gain ... almost definate increased top end ... especially in turbocharged applications
So go and hit up all your mates that own GTiR's (the ones who have upgraded to hks cams and valve springs) for their old valve springs
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Alas, never imported into the US.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
maxnix wrote:Alas, never imported into the US.
but easy enough to get. Theres a few SR20DETs for sale in the BST forum, and SR20 parts are everywhere.
Ezekial
damn ... we didnt get them here either but they are common as hell now via jap importers
i ended up getting mine for nothing off a mate who blew up his GTiR engine and bought a spare and had it built ... 2 x 16 = 32
for the record ... i was told normal sr20 is different ... must be the solid lifters GTiR version
elwesso
2007 BMW M Coupe
what kind of gains would we get by doing this to a stock VH45 N/A?
Ezekial
unfortunately i cant answer that mate
perhaps one of the big wigs like Q45tech or maxnix etc can express their opinions?
Q45tech
Stiffer valve springs wear the cams and followers and seats faster. The HLA design must be changed to adjust for higher spring pressure.
Q45 rpm limits are dictated by the stroke [piston speed] and the strength of materials of rod bolts and rods. Titanium rods, etc
Ezekial
Q45tech wrote:Stiffer valve springs wear the cams and followers and seats faster. The HLA design must be changed to adjust for higher spring pressure.
no offence but that is just so generic. i was kinda hoping for some personal experience rather than a text book recital.
Of course they wear the cams more however a 20% increase in seat pressure to eliminate valve bounce and float in my case is hardly going to increase wear significantly
I've heard this all before. I didnt listen. I went the "terrible way" of regrind camshafts, thicker shims and uprated valve springs (on my other vehicle's engine) ... peak power rpm shifted from 6500 rpm to 9000 rpm!! max rpm shifted from 8000 to 10,000 rpm!! This was after the experts told me there was no gains to be had from valve springs. After nearly 2 years there is no sign of wear on the lobes or on the pre hardened shims. The cams were not hardened either. Just work hardened via 500 km's of easy driving. So you would think if any cams were going to wear it would have been these. no?
Now for the conrods ... correct me if i'm wrong but they are not forged so assumption of failure method would be bending. Given the size of them ... i cant see that happening.
Rod bolts ... i have wondered about these and you make a very good point there. I was thinking of matching up some arp bolts to suit but i cant see 7000 rpm being a problem given the excellent rod/stroke ratio and bore/stroke ratio
HLA design ... mind going into some more detail? i'm interested as to what will/could happen?
defrag010
Valve springs are a dependant mod, and you only need to upgrade them when you exceed the limits that the stock open and seat pressure will provide.
The main factors are camshaft lift and lobe ramp profile, and engine rpm. Without those variables, it makes no sense to go messing with spring pressure..
Ezekial
ever had an engine where the boost pressure was forcing the valves open?
defrag010
No, you would have to be on the barren edge to let manifold pressure create compression bleed fromclosed valves because the equivalent pressure of 30 psi in your intake port would equate to just a miniscule amount of actual force to move the valve open. 30 psi static barometric pressure would be about the equivalent to me mildly pressing it open with my finger.
Boost wasn't the cause, rather it sounds like you were just at the limit of your springs.
