some updates on my HB
pejsa s-13
Car: 91 HardBody, 85 720
so i decided my cooling system could use a little help so this was what i did
i got a fan from a mercedes and squeezed it in behind the grille a ton of trimming was in order
and i had to relocate my oil cooler to the bumper
then i started making my shroud for the other side of the rad
and did a little engine turn kind of deal with my sander for the heck of it
and here it is mounted
ran both fans on the same relay and it seems to be working great!
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
How did you set it up so the fan knows when to turn on? Nice metal work btw. Not sure that oil cooler is very safe though.
pejsa s-13
well im running off the stereo power i think i just grabbed my multi meter and found a hot wire when the ignition was on and ran my positive from that with a switch in my dash and my ground is under my hood somewhere
and thanks
Rev_D21
So the fans run all the time or not?
pejsa s-13
no i have a on off switch for them so if its cold in the morning and i need to warm my truck up i just shut them off till i start driving
silveradobeast
Car: 94 HARDBODY 2.4 5 SPEED
94 d21 5 SPEED 4X4 EXT CAB
PARTINNG OUT A D21
you know that they sale a solinoid and a thermostad that will have the fan on and off that way you dont have to have a switch
is hb your everyday truck?
pejsa s-13
yea i know they do but im fine with the way it is right now plus i just wanted it done cheap.
and yes its my dd
but not for long
Rev_D21
Perhaps this might be good for automating the fans. http://www.dakotadigital.com/i...1.htm
silveradobeast
PARTINNG OUT A D21
i understand so are you worried about your oil cooler being there?i would be scared sh!tless of a rock or something hiting my oil cooler its a great idea but i would get a shield or something
i guess im paranoid!
pejsa s-13
haha yea im a little nervous but hopefully soon ill get some steel braided lines and make a little shield for it
