jonseyq45 wrote:
The rear turbo mount uses a long connector pipe to the intake, What if we used that length as a intercooler? Build a pipe with an integral water jacket. This in turn will connect this to a small secondary cooler\radiator. An electric pump will used to circulate the coolant.
You're thinking along the right lines however you really need to use an intercooler since only the air molecules near the outside of the pipe will be cooled in the setup you've described.
What you need to use is an inline air/water intercooler like this:
