I'm changing the drive line lubricants on my '01 manual transmission PF this morning, and I'll comment here as I go along.
They've been in there for 215K miles. I used Valvolene DuraBlend Synthetic Blend 80W90 in the diffs, Valvolene
High Performance 75W90 in the transmission, and will use Valvolene DexMerc in the transfer case on another day.
The front diff oil was much much cleaner than the rear diff. The front oil looked new, the rear diff oil was black.
I was really glad I had
http://ultimatetoolco.com/13mm/. The fill plug for the rear diff wouldn't come loose with a
breaker bar. I put this gizmo on Ingersol-Rand's baddest 1/2" impact wrench, and it came lose, but not immediately. This
is a good reason to remove fill plugs before drain plugs.
Do the front diff before the rear diff. They take the same oil. You get almost all the oil out of the bottle into the rear
diff, but not so much into the front diff. You can use three partial bottles on the front, and finish them on the rear.
The oil for the front diff looked great. I don't use 4x4 much (just launching and retrieving my boat). I'm not sure I'd
bother changing the front diff oil next time.
Getting the fill plug back into the front diff is tough, at least for my big hands. I'd suggest having handy 6" extension
for 1/2" sockets to get it started.
When I pulled the fill plug for the transmission, a fair amount of oil ran out and made a mess. Have the drain pan
handy.
You can fill the front and rear diff by squeezing the bottles, but no way for the transmission. I picked up this:
http://www.summitracing.com/parts/SPE-5971/ on a $20 sale at Summit Racing (THANK YOU to whoever posted
that sale over at CorvetteForum.com). I discarded all of the hardware, kept the pump and hose, and it filled the transmission in no time
flat. The pump does suck a little air, so I gave it a breather at 4.5 quarts and 5 quarts to let the air get to the surface.
I'm going to do the transfer case another day. It also needs the pump, and I need to clean out the pump hoses.
Chuck
