C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Mon Nov 22, 2004 8:38 pm
The tangential T3 turbine would put the turbine closer to the brake master cylinder. If you chose to continue with the T3, then I would add a heatshield to the turbine and to the master cylinder. What part was catching on fire btw? When I had my T04 On-Center, I wraped the reservior with heat resistant material as well.
As far as the rev hard, it is a good cast manifold. The only real big issue is the expansion. It uses a single head mating flange. Cut it into 4 clanges and this should relieve stress when it is expanding. Perhaps drill out the holes for the head to exhaust mani studs to avoid sheering off the studs under extreme heat. You can also go as far as removing the cast flashings so those don't become a starting point for a stress crack. Lastly, the ports in the mani are circular while the ports from the KA head are squarish. if the previous owner has not done so already, you may want to match port the mani. Not hard with a drill or dremel tool.
