some quick help
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
ok i bought a new turbo outlet pipe for my redtop, the problem is, is that the 02 sensor i had for it does not fit the threads however the KA's 02 sensor fits. The wiring is completely differnt so thats out of the picture. Now i read that 300zx 02 sensor is the replacment sensor... is that the same size as the one i have or same size as the KA. please help and thanks for your time
S13240
I'm assuming you probably bought a black top's 02 extension pipe instead of the red top. The red top uses the thin o2 sensor while the black top uses a thicker o2 sensor.
Here's the Nissan oem part # for the slim o2 sensor just in case. Nissan Part Number 22690-19P20
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
I had the same problem with mine about a year ago, then a buddy of mine told me that megan racing had a fitting to fix that problem, and they did...I dont know what the part number was, all i did was get in contact with them and told them what the problem was and they hooked me up.....problem solved.......
boost_creep
Car: 92 sr powered coupe,06 Spec V
would the redtop still be ok with the large o2 though?im running the large on my redtop now,it seems like it runs fine.figured id ask though.
S13240
it's fine
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
so can i get a black top o2 sensor and use it with my redtop. and if i can what is the part number? thanks for all the help so far
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
the fat-type blacktop sensor is the same thing as a 95 Z32tt sensor.
i dont know the factory number...however phase2 sells them
here ya gohttp://phase2motorsports.store....html
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
ok thanks im going to try it... all the wiring is the same right? is there anything i can do to eliminate the o2 al together
Modified by nissans13240sx at 5:07 PM 6/26/2006
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
bump... does anyone no if the black top o2 sensor wires right up? or how to eliminate the o2 all together? anyone??
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
bump...
ILikeMy240sx
Car: SR Power
technically you shouldnt use a fatty o2 sensor on a redtop ECU because the way skinny o2 sensor sends signal (Titania) is different than the way fatty o2 sensor (Zirconia) sends signal.
Personally, Im running a fatty one on a redtop ECU and Im sure im running somewhat rich because of it.
If you can try to get a redtop o2 sensor to work.
If not you can wire up a fatty one. The middle of the three wire is the signal and the two outer is 12v and ground for the heater. Polarity does not matter.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
yeah im probably going to do that. still open to suggestions though. thanks for the help
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
bump
