Oh
KATwo40 wrote:The only forged low compression pistons for the KA are .020 overbore. So, now you're looking at the cost of boring added to the mix, and hope they do it right.
KA stock internals will hold 350whp no problem, SO LONG AS YOUR TUNING IS GOOD.
I say, depending on what the tests show, re-ring it, new valve stem seals, new rod and main bearings and rock on.
350 is plenty for me.. If you say stock pistons can support that. So you say to put new rings, valve stem seals, and rod bearings and main bearings, any idea what those parts will cost me? Also can you recommend a good size turbo, manifold, wastegate, etc. I already have a place im bring the motor too, so i just want to get some numbers. Thanks
