Postby
wishihadas14 »
https://forums.nicoclub.com/wishihadas14-u77590.htmlWed Oct 31, 2007 3:49 pm
Hey, I am in the process of buying a car that needs cams to be complete. It's fully built bottom end and I plan to turbo within the next 12-18 months, but I need it to be a dd in the meantime (not to mention that the motor needs to be broken in). I was thinking about brain crower's 264/264's but after some searching, it looks like that would pretty much kill any chance at gas milage. I couldn't find that much info on different cam setups, so I thought I'd ask and see if we can compile some info into one thread. I'm looking to make ok NA power till I can turbo, so I need a cam that could put up with mild to moderate boost. I also can't really go too much below the 25 mpg mark either. What do you guys suggest? Also, I need some info on the advancement/retardment of whichever cams I decide to go with. The only setup I found good info on was 240/232, but the gas milage seemed really low. Thanks in advance for any help.
Postby
wishihadas14 »
https://forums.nicoclub.com/wishihadas14-u77590.htmlThu Nov 01, 2007 12:10 am
For those who don't want to follow the above link, it's a KA24DE built wiht CP forged 9:1 pistons, Sportsman rods, and a Fidenza flywheel on it now. To get it running, I plan to use a SPEC clutch kit, a DC Sports Header, APR head studs, but I still need help with the cam set-up. Please?
Postby
wishihadas14 »
https://forums.nicoclub.com/wishihadas14-u77590.htmlThu Nov 01, 2007 1:27 pm
and come to think of it, how would the stock injectors and a lower compression ratio mean less ga milage? Not trying to be rude, I want to know your rationale. Still waiting on some cam info.
