Some questions and small problems..
93Black S13
Car: 1993 240sx SE
Hi, i have a 93 Hatch, with a recently swaped KA in it with 26k miles on it, and also got a new radiator and clutch.
First off my car is loud,from the fan, like diesel truck engine loud (without the turbo spool ). My fan isn't loud on idle but as you accelerate it gets louder. Anyway to fix this or would i have to put in some electric fans?
Also water tends to leak into my trunk and there happens to always be a puddle where my spare is. Any possible ways for water getting in other then the hatch?
Now, as for the engine. The engine bucks when im trying to keep at a constant rpm or speed, the gas only pressed in a little. Engine doesnt buck anymore if i add more gas but then im starting to accelerate.Also when im adding more gas, a sucktion like noise can be heard, as if i had a tiny tiny tiny turbo...could it be the air sucktion even tho the gas is not pressed in that much?
I know theres some more porblems that I cant think of right now..TIA
hannibal
Car: Red Line to Glenmont
The leaky hatch is usually caused by rust under the spoiler....
240sx2soon
Car: Soon to be 96 240SX SE
I may be off base on this cause I don't know if it;s possible but could the motor fan be on backward? that would probablly make an awful noise me thinks
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
the water in the trunk is probably because there is a hole rusted in the hatch under your spoiler. probably around the bolts that attach it to the hatch. i had the same problem.
