Some question about these stuff
Vahagn23
Car: Nissan Versa S
Hi i got some questions about the features of Versawhat is Electronic drive-by-wire throttle?Nissan Direct Ignition System?
thanks
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
Drive by wire uses an electrically operated servo (motor) to open and close the throttle, the "gas pedal" operates a variable switch, telling the computer how far to open the throttle. Direct ignition system is a solid-state ignition system, consisting of one coil per cylinder, activated by the camshaft position sensor. Your car is also equipped with NVVTS (Nissan Variable Valve Timing System), similar to Honda's V-TEC.
Vahagn23
Car: Nissan Versa S
cool thanks
