Some Progress!
John Dixon
Car: 300ZX-TT Z32
Not on my engine, but Leigh's (one of the the other Z32's I'm doing - 3 now). Finally started to get it built back up yesterday after the heads returned from proting. Would have got further, but can't find the bolts that hold the exhaust cam sprockets on - imagine using M7!! Still, it's only prevented the covers being tightened up.
Rex
Car: None
Oh so clean ... looks so pretty. The dyno sheet will be prettier .
John Dixon
Car: 300ZX-TT Z32
Dyno should be interesting although this is the tame one: standard bottom end, ported / flowed heads, IR intake and custom headers with 258° cams and emerald management.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Tame is good for the street. Love performance, but 13 mpg would be tough to tolerate.
Also looking forward to dyanmometer graph.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its purty indeed! Cant wait to see how they actually work
rsiwicki
Car: 95 Q45T
looking great John....I am leaving for London Nov. 16th for 4+ weeks so if you need something that I can easily carry over with me so you don't have to pay import duty taxes let me know asap.
cheers..rob
John Dixon
Car: 300ZX-TT Z32
Thanks for the offer Rob, but I think I've got everything from the US side now. Unless you can come across a cheap 2nd hand set of the cut-out covers off the rocker boxes (the ali ones that you can remove to see the cams). If not I'll just knock some up out of sheet.Cheers
RobertsnewQ
John - are you getting your core engines from the US or locally?
John Dixon
Car: 300ZX-TT Z32
From japan. Works out cheaper for me, and usually low milage too.
RobertsnewQ
Do they ever come with ECUs? I'm trying to find a JDM ECU to read...
John Dixon
Car: 300ZX-TT Z32
Afraid not! Could probably get one for you if you wanted though, would need to check it out.
Ezekial
Car: 2001 Nissan 200SX S15
John that looks awesome!!
Are the front covers coated or painted in anything?
Or just some time spent in the bath?
John Dixon
Car: 300ZX-TT Z32
They were just bead blasted to clean them up, do look pretty good actually.
