darkstar575 »
https://forums.nicoclub.com/darkstar575-u69765.html
Mon Nov 26, 2007 1:37 pm
First off my idle sucks. It surges and sometimes dies. I set the tps, at higher throttle it will stay around 1200 without surging. Once the idle lowers it surges.
Secondly, once in a while I'll be driving and I'm pretty sure my ignition dies on me somehow...Lets say I'm on the gas...If i'm in gear my engine will keep rotating but my throttle will become unresponsive. It feels exactly like driving in gear then turning your key back. Your engine rotates but you get no spark...What would cause this? Ignitor, cas, ecu,green relays, If anyone has experienced this problem please let me know. By the way it usually happens for like 2 seconds. The other day it happened for like 5 seconds.
Third, I have a noise coming from the transmission. Almost like there's something bouncing around inside of it. It stops once I hold the clutch down. It also gets louder when I downshift to first or second. Throwout bearing?Thanks guys!Here are some pics of my work in progress!
