udelslayer »
https://forums.nicoclub.com/udelslayer-u7190.html
Tue Jun 22, 2004 2:19 pm
the shimmy....check your tire balance.check your tires.check your brake pistons and make sure they're not freezing like mine. older pistons tend to stick and dont retract as easily.
the transmission...buy a transmission, easy to replace, easy to afford. a synchro (prolly brass) is a toothed device that matches engine to transmission gear rotation to allow smooth engagement. when you "grind a gear" you're usually grinding the synchros.
