Just thought it might be helpful to others if I posted pics of the parts I installed on my 94 Q. You could compare the part #'s and pics to others if you are hunting a bargain on Ebay or such.
Water Pump - Part # 21010-67U28 / $93.75 from Joe:
The weep hole will start to leak when the diaphram inside goes bad (why my Q was losing coolant). It will look like the bottom bolt is leaking. Liquid gasket is used:
The PFR5G-11 platinum spark plugs - Part # 22401-1P115 (came as a set of 10):
The thermostat - Part # 21200-60U02 / $8.71 from JoeMine was pretty bad as the gasket had eroded and the suspected culprit of irregular temp readings (it would decrease at highway speeds), thermostat housing is liquid gasket. I would recommend replacing this if doing a water pump install:
All three belts (assuming no AC mods) - Part #'s Alternator 11720-60US1VW $11.39, AC Compressor 11020-60US1VW $8.44, and Power Steering 11950-60US4VW $14.05. I would recommend getting all three and especially do them if replacing the water pump. They are kinda a PITA and don't spend 1.5 hrs trying to get them to fit. The crankshaft turns clockwise so start them on the underside for the alternator and AC compressor and give the engine a bump and they should go on. I think you have to start the water pump on the top half:
Valve cover gaskets - Part #'s Driver's side 3270-67U00:
I'll post the passenger side when I get it from Joe, they are different as the sensors on the front of the covers are different, 2 on driver's side and 1 on passenger side.Joe offers at least a 25% discount and it really helps, super cool to deal with too!!
No more leaks and no more stalls, now all I have to do is the valve cover gaskets and spark plugs!!
