Some pics of what I've been up to the last few hours...
MYK
Car: 1995 240SX SE, 1997 GTI-VR6
my timing chains have been rattling like madmen. Decided I was gonna stop driving it and fix the fugger. I have my GTI so no big deal. Anyway I did some looking around and found all the info I needed to get started. Pulled the valve cover
the infamous upper guide
then I pulled the upper guide off
Is it just me or is the guide just a piece of metal? Was there originally some sort of lining on these things? Mine had some slight grooves in it.
The I pulled the upper timing chain cover and dist off
here is the lower guide I pulled off. Much deeper grooves in it. i think it was the one causing all the noise I was hearing. Again is this just a piece of metal designed to chew into the chains?
well I'm gonna finish watching Overhaulin and cleaning up the upper chain cover mating surfaces and get this thing back together so it can set up tomorrow. Hopefully I can come home from work tomorrow, fire her up and not hear any more chain noise! on a side note my tensioners seem to be working good....
myk
corn322
Car: 1993 240sx
good stuff. Mine was rattling bad, so I pulled my cover to find the top guide had broken apart. It seperated at the end right at the bend before it bolts to the head. I bet my lower guide as broken too, need to pull the front off one of these days.
