Some noobish questions while finishing up the RB
KlanjacOFF
Car: Nissan 240SX
Where should this line go to? I think it may be for the charcoal canister...not sure. Should I plug into one of the Greddy nipples, can I cap it off or leave it unplugged?
Is this the fill plug for the transmission?
And last, can anyone identify this shifter? It came with the engine and I didn't think anything of it until I tried to put my Nismo shift knob on it and it didnt fit. So now I need to know what size threads those are to get a new knob. I tried to look it up but couldn't find anything that looked like it.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
1) Looks like thats the line from the canister that returns to the tank. You can cap it or vent it.
2) Transmission Gear Oil Fill Plug
3) Shifter looks to be an el-cheapo from the looks of it, but could be wrong. Use a thread feeler to measure the threads. I think the Toyota/Honda thread is the one you're looking for.
s13point5
Car: 89 240sx
what mounts are you using? that shifter looks to be sitting pretty far forward.
KlanjacOFF
Car: Nissan 240SX
Thanks Coolwhip!
I'm using Mckinney mounts, which I will never, ever use again or recommend to anyone because of how ****ty they were. They might as well be custom mounts now. The transmission mount bolted up perfectly but the engine mounts were way off. I had to drill 3 new holes in them for it to bolt down. Thats not including the ones they tell you to drill on the bottom. Wish I could've found an R33 crossmember to use. oh well
gawdzilla
Car: none
KlanjacOFF wrote:Thanks Coolwhip!
the mckinney's worked fine for me and a lot of other people. did you talk to Mack about it? he is always willing to work with you if something is not right. they are made in a jig so they should fit properly. unless you are using different block mounts, crossmember, etc.
Modified by gawdzilla at 2:24 PM 7/29/2008
s13point5
Car: 89 240sx
i have mckinney mounts and they worked perfect for me. and my shifter is dead center of the hole
BoostFab
Car: S13cp, S13fb, S14z
or could it be opposite side (installed wrong) LOL
perhaps a warped xmember
KlanjacOFF
Car: Nissan 240SX
Definitely installed them correctly. Could be a warped crossmember but I doubt it, or maybe the guy who had them before me somehow managed to mess them up, as I did buy them used. Not sure, but they are on now, I never had time to contact Mack as it was late at night and about to rain so I drilled new holes and got them in. The shifter seemed to sit pretty much in the center last time I sat in my car...might be the angle of the picture.
coreansurfer
Car: painted s14
i have the mckinney mounts; and i've had them for more than 2 years, they are awesome.
slociv
Car: A shop full
Shifter,thats the lower half to a short throw shifter, theres a bulky peice that threads on to that then the shift knob theads on..
FAST-DATSUN
KlanjacOFF send me some picture of the engine mount installed with the block adapter showing and I will help straighten out you problem.. there must be a problem with the install or maybe previous owner did some thing , but we will help you get it right ...
Mack
Coolwhip
Vendor
<3 mack
Carl H
that is a c's shifter, you're missing the extention for it that the normal shifter bolts to.
neonbomb
Hahahaha thats awesome. So much for the almighty, way too popular mckinney mounts.
This just made my day. I do feel bad it happened to you though Klan, it had to start somewhere.
Coolwhip
Vendor
I wouldn't rule on it. mack is actively seeking to see what might be the problem.
After X amount of kits leaving their operation and the failure/illfitment rate being as low as it is, this might very well be an end-user issue.
Either it was done by the previous owner of these mounts or what.
