some noob questions... will the 1.6L 16valve fit the 2.0L
raphenry
Car: 1990 Nissan Sentra 1.6L 16valve 5-speed
Will the 2.0L from a 90-1/94 INFINITI G20 or 91-93 NISSAN SENTRA SER fit in the 90 Sentra? I mean will it bolt up to the trans and everything? If not can I install the trans from the 2.0 into the 90 sentra? It is the 1.6L 16 valve motor...
Thanks
Modified by raphenry at 11:21 PM 1/15/2010
ABNRML4U
Car: Nissan B13
Welcome to NicoClub! Everyone here is nice and cool this is a general Info. that you need to know.GA16 -> SR20DE(T) swap info
-SR20DE(T) Motor-SR20DE FWD Transaxle-Driver side axle-Passenger side axle-Crossmember-All SR20 Motor mounts-Front motor mount bracket-Rear motor mount bracket-Transaxle mount-SE-R clutch cable (not needed if still using auto)-SE-R throttle cable-SE-R clutch cable bracket (bolts to transaxle)-SR20DE(T) ECU or G20 ECU (make sure if you're using OBDII or OBDI or use the right ECU)-SR20 clutch kit (throw out bearing, clutch disc, pressure plate)-SE-R wiring harness
raphenry
wow just looked under the hood. It is a late 91, so a 92 model, and it says it is a B13. I feel a little embarrassed, **** but still wonder if the 2.0 will bolt up to the 1.6 DOHC transmission.***** sorry, just read the message above again, i see.... Edited due to being a noob.....
thanks
ps thanks for the welcome...
