First off--sorry for all of the seemingly endless questions; i've been busy with my car lately!
Okay..so I was stupid and didn't put the engine at TDC on #1 before I did the install...which isn't actually necessary if everything is done perfectly and nothing is touched. However, I like to be 100% safe.
Heres how my car lies:Distributor is off completely, all plugs/wires are off, cam sprocket cover is off, upper timing chain/tensioner/BOTH guides are off.
Now, the new chain has three special links on it. one is supposed to line up with the idler sprocket punch mark, one is supposed to line up with the left cam sprocket punch mark, and the last one with the right cam sprocket punch mark. They all do. Is this enough insurance to say that everything (the crank/lower timing chain) and the upper timing chain/sprockets/camshafts are fully in-snync? Obviously i can't tell because the engine's not on TDC, and the pics in my FSM are all at TDC on number one.
If this isn't a 100% indication that everything is the way it should be, if I were to put the engine on TDC for #1, ie, rotated it using the crank pulley bolt, and left the distributor out, and left the upper timing chain off, could I then align the two cam sprockets, attached to the cams, to line up with the other 2 special links, and assume everything was at TDC assuming it looked like this book picture (see pic).?
http://www.eniety.com/pichost/pic/121-2182_IMG.JPG
http://www.eniety.com/pichost/pic/121-2183_IMG.JPG
Then I could align the distributor gear to how it is shown to be aligned when installing it in the engine if the engine is at TDC on number one, and call it a day? It seems to make quite a bit of sense...assuming it's TDC verified by the crank pulley, and the link on the timing chain is lined up to the idler sprocket, and the other 2 are lined up with the 2 cam sprockets...(see pic)
http://www.eniety.com/pichost/pic/121-2184_IMG.JPG
http://www.eniety.com/pichost/pic/121-2185_IMG.JPG
Or is this all useless and should I just accept that because those three links line up, everything is how it should be? I just want to be 100% positive everything is synchronized
Sorry, but all of this stuff is confusing the hell out of me.
Someone (who knows what they're talking about) please help!
