AZhitman wrote:greenwar - My mistake on the plugs, I read it wrong. Definitely get the NGK's.
Check with our sponsor, sparkplugs.com, let them know you're a NICO member for the discount.
AZhitman, Thanks again.
This time I was in a hurry to get the older crappy stuff out of the car so I bought parts locally. Next time I will order from the sponsors to support this site. Got few things changed today. Car drives like a dream.
1) OIL change with K & N filter2) K & N Air filter3) NGK plugs - car had crappy bosch plat in there, now there is no vibration in idle4) Cleaned throttle body5) Changed fuel filter - big pita6) checked diff oil - seemed ok - didnt need to top it off7) checked coolant seemed ok8) older plugs had good signs of clean burning cylinders9) No valve cover oil leak
Over all car seems to be in good shape mechanically. I will get the transmission oil plus filter replaced soon. transmission oil seems very nice though.
I want to take the opportunity to thank you guys. Without your help and without this forum it would have been way harder.
