PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Sun Mar 20, 2005 3:03 am
Hmmm... I've been trying to struggle with this on my own for a while, but Haven't gotten the results I'm hoping for.
I did find that the ground wire that comes off the passenger side of the motor (it comes out of the same harness as the fuel rail connectors) was not even close to tight. Fixing that seemed to help considerably, but not enough. It won't miss as bad in first anymore or really low throttle, but it still misses at idle and when crusing in low gear. It's about 2-3 misses per second, and it is reallly annoying. The missing goes away when you put a load on the motor, be it throttle or higher gear.
I would like to diagnose the ignition system, but I have my old '91 240sx FSM and this is a '95. So maybe there are things I can check if someone would let me know exactly what? I have a multimeter
I just checked for codes last night, just out of curiosity. Got a code 41 (air temp sensor. Which I didn't have when I swapped in this motor, but I doubt this could be it. Could it?), also got a 82 (Crank Pos Sensor, this one is intermitent... sometimes it gave me this code, but I checked it later and it didn't. But then I checked again, and it did!) and the last code was an 84 (A/T Diag Comm Line.. no idea what that is, but I think it's from the auto to manual swap. Something must not be hooked up or wired or something.)
I still wonder if it is a ground somewhere acting up. Maybe the ECU ground is no good?
Any ideas?
