I can do 9400rpm at 33psi, and I can tell you what HP you can expect from 1000cc injectors, but injector size doesn't come into play when determining mass flow rate.
anyway, here's your stuff:
for plotting on a compressor map, you'll need this number as your pressure ratio: 3.35
CMf or Corrected Mass Flow rate: 68.89
Now for HP, I'm gonna assume your running race gas, and alot of it, so I'm gonna tune the A/F down to 12.5 ( just to be a little conservative
) and your BSFC to .50
Your HP @ 33psi @ 9400rpm is 660hp w/ race gas tuned to 12.5:1 A/F and a 50% BSFC
now for those 1000cc injectors, you can expect to pull 760hp with a 50% BSFC
Now, looking at the Garrett GT37 Compressor Map, we can see that it is not on the map, and a GT37 will not be able to spin to 33psi. Looking through my other maps, I can see that a GT42 compressor would work, but that's as small as you'd be able to go, a T66 compressor will also work well for that set-up.
