I searched Google for info on turning rotors (I was unfamiliar with the concept), and this is what I found:
http://www.team3s.com/FAQrotors.htm
From
http://www.davefancella.com/in...Drums :Quote »Turning MetalTurning rotors and drums is just the act of shaving the outer layer of metal on the actual friction surface. This requires an expensive brake lathe and is usually beyond the scope of a home mechanics resources. Luckily, most auto parts stores will gladly turn your rotors and drums.
But should you get them turned?
The Great Debate on Rotor TurningFirst, let's examine why we turn rotors. A good brake technician will tell you that we turn rotors so they'll be perfectly vertical against the brake pads. This same good brake technician will also tell you that if the rotor is warped (noticed through a pulsating brake pedal) then it is bad and *must* be replaced. So if my rotor's not warped, then it's already perfectly vertical against the brake pads, right? Then why should I turn the rotor? The good brake technician can't answer that question.
The great brake technician can. He'll tell you that cutting the rotor makes a raw surface available for the new pads, will cause the new pads to generate a bit more heat and will help them to seat properly against the rotor. In the long run this will actually increase the total miles you get out of the brake job. He'll also generally refer to 'turning' the rotor instead as 'resurfacing'. It's important to remember that turning the rotor is actually 'resurfacing the rotor'. You're putting a new surface on the rotor, that's what you're doing.
So should I turn my rotors when I change the pads?
I say 'not usually'. I also say 'sometimes turning the rotor causes more problems than it's trying to solve'. Consider that each time you turn the rotor it gets thinner. Thinner rotors warp easier than thicker rotors, and most people actually drive their cars a little wrong with regard to their brakes, so you want as much metal as possible on your rotor. If you want a more abrasive surface for your pads to seat against, using a heavy grit sandpaper on the surface of the rotor will provide that. Just sand it 'till it's shiny and go with it. Keeping in mind always that resurfacing the rotor is the *best* thing you can do. In fact, if you have the money to do it, go ahead and take your rotors down and get them turned. It's really the 'right way' to do it. I don't, though, because I have a great deal of experience to back up my decision here. Unless you have similar experience to back up that decision for yourself, I really do think you should get them turned instead of taking any chances. The quality of your brake job is going to directly affect the safety of your vehicle, so don't cut corners.[/quote]I posted this as a resource. If anyone has any more information, please feel free to post it here.
