Dude, i live in Edmonton (Canada), and theres already a few people here who have done the swap .S14-NEO wrote:CRAP!!!! not another one...i kinda liked being one of a select few who owned a NEO
well did you buy it already done or did you build it yourself...typically if any RB is in stock form they are much trouble till you start trying to extract triple the hp out of themneonbomb wrote:I have a neo and its annoying as hell
thanx man, im putting the neo into an s13 not s14, but almost same engine bay, my question is, do u have an suggestions or things to avoid or something in that area while doing the swap? like things to replace, or watch for, wat parts to use, i mean little things that might not be noticeable at first or not pay attention to, later to scram "AWWW FAWK!!!!"S14-NEO wrote:CRAP!!!! not another one...i kinda liked being one of a select few who owned a NEO...lol...oh well guess thats out the window now..but if you need some info on how to's and what not i may be able to help.
the neo package that im going (hopefully) to pick up, it comes with an r33 rb25 transmission....when refering to pull style and push style, is that inside the transmission, were the cluch is beeing controlled or dose that refer to the salve cylinder, no problems should come up with the r33 transmission right?Thanielson wrote:ya poor s-14 only like 3 people on Nico have one that i know of poor guy . the neo isnt a bad choice if i were to do one from scratch and not buy one id prob still get a neo. every problem from the s1,2 and 3"neo" are in all of them **** turbo, crank snout, and ring lands"top ring". but i think the pro's out way the cons bigger exhaust turbo housing, soild lifters, 1/10 lower emission's, lower miles, rb26 rods, and the covetied neo cover. some small things like the pull style clutch some thing it is not worth it a pull style has a better engagement then a push and lets face it when you but a rb the hole money thing really doesn't matter anymore it is all expensive and remember as for most car parts you get what you pay for. the cooling issue if it is done right you wont have a problem. ie a good fan setup, having cooling panels on the top and bottom of the rad and sides, make sure the cooling system is filled properly no air traped in the system, a good radiator my oem ka works just fine. as for the piston ive heard they are better and ive heard they are the same as the s1,2 rb25s non were from Nissan so idk. oh and ya i know my grammer and punctuation sucks.
no you should be ok but in the event that the NEO did in fact come with a NEO style clutch you will most def have to go with a R33 style which is in fact a push style rather than a pull. and why would the NEO engine that your getting not come with a NEO trans...that seems kinda odd unless it was perhaps an auto orginally.Old240RB wrote:
Its been a 2.5 month buildup so we'll see if it runs this weekend. It better is all i have to say.S14-NEO wrote:
