slw240sx wrote:i thought the det block was a DE block with piston squirters turbo pistons,crankgriddle , and rods?
That's also what I read, but that's not what I found in this case, no crank girdle here and the rods are the same as far as I can tell besides the # on them.
boost_boy wrote:The rods are the same as the DET units; just you're missing the girdle. Get a girdle from someone as well as the main bolts and call it a day on the bottome end. I've used the older DET pistons in one of my engines with historical success, but I didn't disassemble the motor, so I wouldn't have know it didn't have a girdle in it.
Dee
I probably will snatch up a crank girdle, so I can find one on any RWD CA? I didn't think the pistons would really be an issue, just wanted to be sure.
pulsar gtr wrote:My first none intercooled det FWD came without any crank gridle.I think they only applied the gridle on the 1988-1991 engines, which has the same block/crank/gridle as the pulsar ca18de in North AmericaIf you decide to get a gridle for your engine, I think you need to replace the oil pan as the det oil pans are longer than the dePULSAR GTR
Hang on, the pulsar is supposed to have a crank girdle too??? Mine didn't, am I just getting really screwed here or something? I was wondering about oil pan clearance as well, I won't even get to that point for a while though.
Ok, I added piston and rod #'s up there, the rods have different #'s but appear to be exactly the same??? Here's a pic-
