some eye candy for you/ whoring of my trucks
pejsa s-13
Car: 91 HardBody, 85 720
finally got a camera so i thought id get you guys some pics of my trucks that aren't from a cell phone.
no engine pics of the 720 because its not worthy yet
PEZi
the HB is lookin good man
rizzobc
Car: 1987 nissan hardbody
Dude they look good. Just a queston, how is the line of sight with thw side view mirrors on the fenders? I really like the look. The rims are killer too.
pejsa s-13
PEZi720 wrote:the HB is lookin good man
thanks and if i can get my 720 to look even close to as good as yours ill be set lol
rizzobc wrote:Dude they look good. Just a queston, how is the line of sight with thw side view mirrors on the fenders? I really like the look. The rims are killer too.
it really is garbage lol i need to get one of those super long multi pane rear view mirrors because i cant see anything
PEZi
just wait till you see my 'final product'
although it'll take years
pejsa s-13
well good thing i dont think this website is going anywhere
seang
Car: Ford Fiesta ST
Did the truck come with manual steering or did you swap it?
pejsa s-13
came like that and i LOVE LOVE LOVE it
seang
Car: Ford Fiesta ST
Right on!
I like how you are running the air filter open like that. Just like mine. I think it breathes best like that, but it might just be my imagination (or maybe not?). Just less clutter than the stock intake ducting.
Modified by seang at 8:28 PM 11/29/2009
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Love the rims and love the stance.
pejsa s-13
seang wrote:You should put a breather filter on the valve cover or at least keep the stock one nice and clean. The element gets gummed up, sometimes rather quickly.
Alot of air gets pulled through there, and when the engine gets turned off, the blow-by gasses in the crankcase seep up through the baffling and into that filter element, dirtying it even more. It's the fresh air intake for the PCV, and if it's clogged, it will definitely hurt performance. Cleaning the stocker or replacing it with a little $7 aftermarket piece is a good idea.
The stock breather filter is a little white rectangle shaped thing located in the plastic airbox.
Not trying to power preach this, but I didn't realize how important it was until recently : )
Modified by seang at 7:30 PM 11/29/2009
well the white truck has a catch canisterthat i made for it so the crank case is no longer connected to the intake. its the little red thing to the left of the air filter
i assume your talking about the whit truck
Reverend D wrote:Love the rims and love the stance.
thank you sir
pejsa s-13
yea the pvc from the valve cover runs to that red thing so nothing is connected to the base plate of the air filter(i think thats the answer your looking for?)
and the oil cooler rocks!
i was having problems with the truck overheating with the ac on and the oil coller solved that.
i can drive the truck all day long then grap the oil filter and its not even hot but midly warm
PEZi
seang wrote:Right on! I tried removing the PS belt on my 97 just to see what it would do. I test drove it down my road, and it didn't take long to realize that it sucked. Very unsafe, almost impossible to control.
did you purge the fluid? that's what does the trick... with all that fluid in there YOU are the power steering system... with the fluid out its nice and easy to turn (except low speed tight turns like trying to park)
pejsa s-13
nice im going to have to do that to my 720
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Very nice . A lot of little details that show how meticulous you are.
seang
Car: Ford Fiesta ST
pejsa s-13 wrote:nice im going to have to do that to my 720
Pez explains this more clearly over in the 720 forum in his build thread. zer...age=3
You have to keep enough fluid to lubricate the gears.
I think you can loop the lines together as well. But keep the high pressure line around and don't cut it. They can be kind of pricey.
pejsa s-13
yea it seems like everything for these trucks are expensive $60 air filter$100 dome light enclosurethe plastic clips that hold a ton of stuff together on these truck are like 3.50 eacheven at a junk yard $90 for the front fenders
i think thats pretty crazy
seang
Car: Ford Fiesta ST
Unless some company makes re-production parts, things are only going to get more rare and more expensive as time goes on, particularly with body parts. What this country needs is a car that holds to a philosophy like the original VW. Make a million of them. One style, standardized across the board with bulletproof yet economically feasable engineering.
There is too much exclusivity to have cheap parts.
Modified by seang at 2:24 PM 11/30/2009
Rev_D21
If you think HBs have expensive parts you should try a Millenia, the prices are stupid when it comes to that car. The HBs are inexpensive to maintain in my opinion.
2fizzleforshizzle
Car: 89 240SX 90 240SX
Did you shave the KA valve cover? Also has anyone tried to use 240sx cams/ intake on these trucks? Looks good!
pejsa s-13
yup shaved the stock valve cover
and yes people do the 240sx intake manifold but i havent heard of people using the cams i think the hb's have a higher lobe to be honest do not quote me though
Rev_D21
The stage 1 cam for the KA is basically a 240 profile I believe. I have a cam sitting in my bedroom waiting a regrind.
pejsa s-13
interesting
seang
Car: Ford Fiesta ST
I like the PDM C404.H cam for the KA-E. DeviousKA used this cam in his budget build. Price is about 270 dollars. If I was gonna spend $ on a KA-E build, this would be my cam.
C404.H - Strong performer, with good midrange pull to redline. O.K. with automatics. Our strongest seller with the most smiles! {Intake 268 degrees duration, .441 valve list, Exhaust 272 degrees duration, .447 valve lift.} (note: requires cam towers to be milled .025")
Modified by seang at 10:32 PM 11/30/2009
Rev_D21
You have to shave the towers with that cam just as a warning, it's not plug and play.
240sxStock Cams: Intake 251 degrees duration, .415 lift; Exhaust 258 degrees duration, .415 lift.
vs.
C.406 - mild performance upgrade, that wakes up any stock engine with good emissions results, and good in automatics. {Intake 260 degrees duration, .424 valve lift, Exhaust 268 degrees duration, .441 valve lift.}
PDM says it will work in some HBs as well. No need to grind the towers. This would be a good starting out cam. I personally just grabbed a cam out of a HB with plans to have McQuillen race engine re-profile it for me. With that I will need new rocker arms, Nissan says to replace the rocker arms with any new cam.
seang
Car: Ford Fiesta ST
Reverend D wrote:Nissan says to replace the rocker arms with any new cam
That's for any motor. You could probably get away with using the stock rockers depending on how worn they are (or aren't), but if you want your cam to break in right get some new ones. HybridKA makes solid rockers for our engines. I think they convert new stockers into solid on a special order basis, but IDK the price. I wonder how they do it. Maybe it isn't even that hard.
Here are the stock cam specs...89-90 240sx STOCK cam intake: 240 degrees duration, .409 in valve lift exhaust: 248 degrees duration, .409 in valve lift
90-97 Hardbody STOCK cam intake: 232 degrees duration, .382 in valve lift exhaust: 232 degrees duration, .382 in valve lift
This doesn't match up with what PDM says is stock, and the info I'm posting isn't firsthand so IDK what is accurate. It does make sense that the stock HB has less, though.
Rev_D21
HB built for more torque. Hybrid solid rockers are like the ones from the older engines, get out your feeler gauges.
