Postby
chibinissan »
https://forums.nicoclub.com/chibinissan-u172169.htmlFri Mar 25, 2011 7:37 pm
i goy a little problem in the dash of my truck!!!!
all the gauges are working exept my gas and temperature
i try switching the dash its not that
i try puting power to it it just go all the way (full and overheat)
and they got ground
Take a test light and pull the connectors at the sending units and check for power. If test light lights, leave it connected and see if the gauges move. You can also ground the wires and the guages should read "full".
