CDE »
https://forums.nicoclub.com/cde-u24869.html
Sun Jan 23, 2005 10:05 pm
Thanks!
I had it apart this morning and checked the back of the gauge cluster to look for something dodgey...but was unsuccessful. Unfortunately I didn't have time to dink the the wiring more and check everything more closely, but I was pressed for time. But something interesting happened...after I put everything back together, only 1 little thing changed.... The little clock that is just below the tach, well, that used to never have light to it when I had my lights on during night time, but now - the light on the clock works, and my rear tail lights have stopped working. I didn't have time to check the fuses because I was already on my way home (visiting the folks 3 hours away).
I'm thinking that maybe something is botched in the main harness were all the gauges and other switches plug into. I know all the fuses I checked were fine, and all the bulbs seem to have life still in them. After I dropped the steering column, everything was easy to see and to get at. Sometime this week I will go at it again and take more things apart to check for corrosion and anything out of place. I didn't totally take apart the cluster panel; I just popped it out and looked at the connections.
Things that work on dash: Tach, fuel, and occasionally the temp. gauge, the hazards, rear defrost, all LED warning lights and signals...
Things that are not working: electronic speedo and HUD, cruise control, odometer, trip meter, all background lights, and I think that's it.
Any ideas at all? Is a botched dimmer switch likely at all?
