Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Sat Mar 12, 2011 11:39 am
I changed the belts on my '01 PF this morning. It took about 40 minutes. At 192,000 miles, I figured it was about time. The belts
were in pretty good shape actually. Since I spent more time figuring out just what I needed to do than actually doing, I thought I'd
pass a few things along.
1. First step is degrease. Two cans of Gunk a couple of weeks ago handled that.
2. You change the belts from underneath, and that means pulling the cardboard pan under the engine. So changing the belts
in conjunction with an oil change is a good idea.
3. The FSM shows a bolt and a nut for each adjuster. You gotta loosen both before it moves. The nut may take a good yank to get
loose.
4. It's a bit fiddly but you don't have to remove the fan to get the fan belt free. (I had one vehicle where that was necessary).
5. A right angle power drill is real handy for running the jack screw on the adjuster up and down. And for pulling the pan.
