KASilvia90 wrote:Thanks for the 7500, I was reading anywhere from 7100-8500 and was hoping to get that cleared up.
I heard to stay away from topline peformance brand bearings and stuff, I don't know why though. I was originally thinking clevite or calico if they offer those for the CA.
Would there be any reccomendations on some things to kinda hop up while its being rebuilt? I don't have a ton of spare cash but I was told things like the head studs were weak and ARP should be used beyond stock boost. I dont think its that drastic but are they very weak?.. That should sum up all my questions I was having though and thanks... Once again sorry about the thread "change" lol.
Even though you can go to 7500rpm, doesnt mean you should necessarily be there. The stock cams wont be making any power at that point and you'll be putting more & more stress on the rods not to mention the bolts. From what ive read, heard and research on here and other CA related forums is that the rods and bolts are what will give at these kinds of speeds more or less the bolts. I doubt you'll hurt anything if you happen to accidentally (or not) but if youre constantly there, you just might. With aftermarket rods and bolts for example Pauter rods and ARP bolts, the problem goes away but then youve got the cams and valvetrain to worry about. I doubt you'll be going past 8000 even 9000rpms anytime soon.
I say use Nissan Factory bearings or if you'd like to "step it up," use Clevite or Federal Mugols. Im sure any of these will get the job done! Anyone else using any other types?
Head bolts can hold upto 300hp according to a well known member on the board. I agree. So can studs, which are known to be yet stronger than bolts. Im going to say it depends on the tune. Its not going to be the boost but detonation and lack of fuel or a lean mixture and maybe preignition thats going to cause a headgasket to blow or your motor. Be safe and give the engine more than enough fuel with correct ignition timing!
