after spending, i think, close to $300 on nismo mounts, i'm of the opinion you should just use whatever mounts come with the swap. i think someone said you could silicone glue the gaps, and then get a harder transmission mount. any-hoo, my mistake, they do fit, but you're right about the motor ride height issue for sure. edit: i said "about the same"float_6969 wrote:Sorry fitch, you're wrong about the motor mounts. The KA/SR mounts will work, but the motor will sit up to high and be tilted incorrectly.
The part numbers for the correct mounts are in the stickies and the upgrade guide I wrote.
