Some built questions rb25det
al_v
Car: 1998 240sx
Please, can you tell me if this pistons are stock bore or over bored , I´m not sure about that 05????
And what is the tq specs for the arp head studs???????
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
they're factory pistons.
The extra number is to tell you the various size pistons from factory to compensate the piston to wall clearance between cylinders.
ARP head stud tq specs:
70ft/lbs for ARP Moly Assembly, and 85ft/lbs for use with 30wt motor oil.
al_v
Car: 1998 240sx
Coolwhip wrote:they're factory pistons.
I know that , but my question is , are this pistons standard bore or over bored ???
Thanks for that info.
Coolwhip
Vendor
A list of everything printed on the piston will help.
al_v
Car: 1998 240sx
This are my numbers :
Coolwhip
Vendor
Sorry didn't post the chart, all which is found in the FSM.
Factory piston; Stock Bore
