some bolt size ?s
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
ive done lots and lots of searching, so i broke down and made a thread. im doing a 5 speed swap and i have nearly everything to do my 5 speed swap. well, except some bolts.
what size are the pressure plate bolts?
what size are the flywheel bolts? also, what grade?
what size are the bolts that hold the shifter "plate" on the transmission?
finally, what size are the bellhousing bolts? i know the auto ones are too short so what lengh do i need, i believe there are like 3 different lengts.
thanks guys, i feel dumb asking, but i have been searching for literally every day for an hour or so, all week.edit: just to be clear, im looking for the diameter and thread pitch of the bolt, not the size of the head of the bolt.
Modified by darens13 at 8:32 AM 4/26/2009
darens13
umm anyone have any idea?
locoluna825
Car: 90 240sx coupe
im having the same trouble right now im doing a 5 speed swap and im missing a lot of bolts. they were all mixed up too when i took the transmission of the car so i dont really know whats what, im gonna measure them and buy some replacements soon ill let you know.
darens13
that would bo so awesome! i havent had any luck finding what size these bolts are. no one seems to know. if i come across anything i will post it up.
Firewind
Car: 240SX
The bell housing bolts are 10MM however I am not sure of the pitch. I beleive the OEM head bolts are the same.
As far as the flywheel, order OEM replacements, or ARP, you can't just bolt it up with any old bolts you find from napa... http://www.courtesyparts.com/ has a great list of OEM parts and bolts, they are a dealership out of Texas. I usually order my parts though them since I don't like dealing with the dealerships in MN. I have ordered all my broken bolts through them, that way I get the right size, and don't have to worry about it.
mac_daddy
Car: 92 slicktop n/a
the bellhousing bolts are 10mm 1.50, i just had to buy a new bolt like 2 days ago. idk about the flywheel or pressure plate but im sure you'll get that soon from locoluna
darens13
hey thanks a lot bud!
CoupeS13
Car: 1992 240sx Coupe & 1990 300zx
For the Bell housing bolts
Engine / Bellhousing Bolts
Bolts = 08131-0601A / 60mm length / 4 needed
Washers = 08915-2401A / 4 needed
Bolt = 08131-0701A / 70mm length / 1 needed
Washer = 08915-2401A
Bolts = 08124-0301F / 35mm / 2 needed
Nuts = 08911-2401A / 2 needed
Bolt = 08124-0601F / 65mm / 1 needed
Nut = 09811-2401A / 1 needed
Bolt = 08071-0251A / 25mm / 1 needed
Starter Bolts = 01121-03751 / 95mm / 2 needed
darens13
thanks man! where did you find the lengths?
darens13
so ive done some more searching and apparently the pressure plate bolts are M8 - 1.25x16mm. when i find out the other sizes out i will post them up for anyone else who needs them.
locoluna825
Car: 90 240sx coupe
hey dude i found you a set of bolts you may want to take a look
http://cgi.ebay.com/ebaymotors...A1318
darens13
well what i think im going to do is, just go down to the fastener store and go buy some bolts and get the highest grade i can. im sure they will work and i wont have to spend 30 dollars on bolts.
Triperformance
Or....you could go to Nissan and talk to a lovely parts person and check the exploded view of a transmission and ask what bolts and deminsions they are depending on your needs. Just a though for the wise.
darens13
nothing to lose talking to the douches at the stealership, good idea man!
Triperformance
Yeah....but stealership is a bad word imo, parts may be over priced at first sight but their setting the true value price on factory parts.....hince aftermarket brands making money in most cases trying to duplicate the product nissan made which isnt always the same quality. Always debate on if something is worth going cheep or factory part on, best of luck!
