some body told me stock ser transmission wont hold up what do you think????
spooledyou33
Car: Se-R
I was talking to some one the other day and i told him what i have all the things i got and he said that the 91 ser transmission will not hold up to the bluebird i told him i got a 6 puck cluth so i wanted to know eather what transmission to use or is this just a false statement cause the transmission feels strong as hell
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Well from my sig you can see it holds 280whp. It really depends on how much it has been beaten on,how many miles on the transmission and how well you take care of the transmission. For starters a six puck is over kill unless you are making the kind of power I am. Anything less, there are several different clutch setups that can be used and less harsh on the transmission. I need more info on your setup and power output to really point you in the right direction.
nametakennow
Car: '06 MINI Cooper S
A stock Bluebird motor could be handled by a stock clutch even, but the clutch won't last long. A full face, or if you have bigger plans, segmented Kevlar disc and HD pressure plate would do the trick easily. The transmission itself, as RED said, will do fine if well taken care of (good fluid, not powershifted, etc).
Now, if you're upping the boost quite a bit or adding a GT28 or larger and upping the boost, etc, then yes, it might become an issue.
If it's been beaten up pretty bad, upgrade while you're at it, but don't replace it if it's in good condition.
