Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Wed Dec 08, 2004 6:34 pm
Ok, I am determined to get the A/C system to work properly once the RB26 is installed.
We all know that the only real main problem is the wiring. How are we gonna get the system to be monitored with the pressure switches to activate and deactivate the compressor as needed. On the KA, the ECU does most of the monitoring with the aid of a triple pressure switch. And that I have researched, the RB's A/C Controller does most of the monitoring with a dual pressure switch, and that I have been told. And with comparing the wiring schematics from each car, they are CLEARLY different.
And we all know that when the lines are hooked up and charged, all that is needed to run A/C is to give the one wire going to the compressor power. But as many have seen, we really don't know how long to keep the compressor running before it needs to be deactivated to avoid blowing the A/C system.
Well, I "think" I have come up with a fast and easy fix for this.
The A/C compressor runs for a certain amount of time when the A/C is on, then it is shut off when it reaches its maximum pressure that the triple pressure switch sees. Now, while the KA is still in the car and the A/C works, I am gonna monitor the time intervals of when the A/C compressor is turned on and when it is turned off. So, let's say that when the A/C is on, the compressor runs for 1 minute and then is off for 30 seconds, but is then turned back on for about a minute again, as so on and so on. Well, what I have been thinking is installing a timed relay, or a set of timed relays. Run a power wire from the A/C module to the compressor that is activated whenever the A/C button is pressed. Then, interrupt that wire with a timed relay. So it sees the 1 minute on and then the 30 seconds off.
Does this sound feasible to anyone else before I tackle this?
