nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Wed Jun 19, 2013 6:38 pm
I was able to finesse NA lines to fit with the conversion and the condenser, just slow and small bends. All of them worked fine. You can swap the low pressure for a cleaner look, but the NA ones will work. Pressure switch would be beneficial, safety reasons, but was able to convert to 134a with no issues. I would find a way to make the electric fan to run while the ac is on, I did notice when at stops, it would get warmer. When I started driving, cooled right down, just not enough air moving through the condenser.
When you charge it, do about 15% less than the r12 states. Too much will blow it warm. I am sure your ac clutch is fine. Ad power to the wire and it will engage. If it doesn't, more than likely bad. Still more than likely the no refrigerant.
