Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Thu Jan 28, 2010 4:49 am
Damn dude, if you don't like what the guy is asking in the thread, don't read it. There's nothing wrong with asking questions about a truck you don't know that much about..
OK...
LSD - I don't know if the R200 LSD will work in an C200 axle. I'm not sure why it wouldn't, as they are basically the same diff. See if you can get specs on the breakaway torque of that particular diff. The trouble with an LSD is that it doesn't fully lock - that's why the ARB is so much better for offroading. If you lock up the rear, you may be surprised at how well the truck goes in the rough that you might be happy leaving the front open.
Another option is finding a V6 front axle from a V6 pickup or WD21 pathfinder and bolting it in. You'd need offset mounting bushings to lower the diff about 5/8" of an inch along with a little grinding on the diff pumpkin and rolling the edge of the oil pan a bit for clearance, but that's a possibility. Spencer Low Racing used to sell those drop kits, but they went tits up. I think there's another outfit making them now....google may be your friend.
Even with manuals and a welded front, I'd give it some serious thought. Like I said, you CAN'T hardly turn it when the front is locked, and when you do, something has to give - either traction on one wheel, or truck parts.
I'm not sure what's out there for aftermarket halfshafts. The stock ones are pretty strong though provided you keep them working within reasonable angles.
On a trans rebuild, it's mostly labor. On a 4x4 the trans is a pain to get out since you have to pull it and the Transfer case....as well as the torsion bar crossmember. Shop around and look for a place that sells rebuilt transmissions and can take a core....I think a reasonable wrench can drop/replace one, and since the bulk of the labor is the removal/installation, you'd still save some bucks.
