fender_dude wrote:Did you check the TDC via the damper or manually through the cylinder? I'm having issues where my throttle response is horrible and if I rev the engine lightly it takes it quite a while to get back to idle. It idles just fine though at times it will stay perfectly at 850 but then drop randomly every now and then. How did your car run before you adjusted the CAS?
set the Crankshaft pin at 12" and then set my cas..
DriftBoy07 wrote:What do you have done to your SR? Hows the Emance tune treating you?
everything except cams...the tune was flat and rich...
rc1honda wrote:13.5 under full boost? That sounds lean. I always thought you wanted it at 11.5-12 under full boost.
13.5 was a little lean, but I reset my TPS and got the car running correctly, then used a SAFCII for fine tuning the emance tune
