harryg wrote:ImStricken wrote:if you unscrew the bolt holding your passenger side wiper, and adjust it upwards, you can gain an inch or so without having to go through this trouble everytime.
You got any pic's of this method?
a DIY would be great
ill do a more detailed DIY this weekend, but for now:
take a look at a window wiper
look at the point there it connects to the bottom, by the lower portion of the windshield
all the way at the end, there is a cap thats covering a 12mm bolt.
pop that cap off, loosen the bolt half way and jiggle the wiper arm itself(it might take some muscle)
once you have the wiper arm spinning freely. adjust it about an inch or so from its previous position and retighten bolt.
check the wiper action on full speed making sure its ok (otherwise re-do it).
DONE!
