rivetapproved240 »
https://forums.nicoclub.com/rivetapproved240-u10593.html
Mon Oct 25, 2004 10:24 pm
i have had that sound... the death rattle.... i assumed like most that it was my timing chain... since i heard it from above, not midway or below ( automotive stethiscope.) i concluded it was the upper chain. anyways i remove my valve cover and i have heard that the metal chain guide can be a source of that marbles in a fish bowl sound. I take it off and check it out. It does seem to have some very very slight rubbings but deffinatly enough to tell. when i cleaned all the oil off of it i saw that the back of the chain guide had been rubbed a little deeper... not much though... the chain looks fine... slack is not an issue it is pretty taunt. Now my question is this, should i put it all back together and chance it or go ahead and replace the timing chain. i could spare to save the cash and return the chain since it is a no wear item. if i do replace the chain however, how do i get my car to tdc, i tried turning the major pully and this is a pain in the A**. Its the second notch correct? also down the middle (between cams) there is this kinda burnt stuff ontop of my head..... should i remove it or leave it... its pretty stuck so i dont want to loosen it and not be able to get it all out.. i have searched for these answers but the new format has got me all searched out with the wrong results.
